Charging problem on sony xperia m2
Supriyomldt
Visitor
I have this problem like when I am charging my device the charge is showing but its not getting charged infact the charge is decreasing so I took it to the mobile repair shop and he changed the charging IC ,now the charge is increasing but the increase rate is too slow and he said that the charging IC is getting heated up which is damaging the IC. Any solution?
4 REPLIES 4
profile.country.US.title
Qatrium
@Supriyomldt
Did you try different chargers or USB cables?
Supriyomldt
Visitor
Yes. Nothing worked. The ic is getting hot.
Loyr_Tajan
Visitor
The same on what is problem on your phone
-- WHAT SHOULD I DO ?
-- Help me
Uliwooly
@Supriyomldt
Time to contact your Local support  to get it inspected.
@Loyr_Tajan
Could you test your phone with a wall charge and in >>> safe mode ?
