camera
Wolfy1
Visitor
camera
I had a failure in the camera. When there is low or strong ocean light it is always passing through it like a strong flash of white light. Before I did not, this problem is in the back camera. When you focus and there is a lot of light, the image is adjusted and the excess light decreases so that the photo looks clear. Now I do not have it, when I have it and there is a lot of light, it is half blurry, dirty or the image is simply not visible. I've already done tests with the front camera and it works correctly.
1 REPLY 1
profile.country.US.title
Qatrium
@Wolfy
Do you have a protective case or cover on your phone?
Can you also inspect the lens to check if there are any scratches or damages?
