My DVD Recorder, HXD995 has developed a fault with the Guide. It does not display the prog guide and therefore I cannot record TV progs anymore. The TV and TVs own prog guide works fine so the Aerial in/ Aerial out to TV is not the prob. It seems the HDD Tuner is not storing the data !!
I have checked the leads...all was OK previously and recoreded OK up to last week.. I have a fair amount stored on the HDD (70%full) and have tried most things. The manual does not cover this prob so can I try to RESET THE RECORDER to factory settings as suggested. Will this erase any progs stored on HDD ?
Any other suggestions ??
Disconnect the aireal and do channel scan obviously it will find no channels reconnect again and do a another Chanel scan this worked for me
