I've been having some issues with I assume is the settings in the receiver and was hoping to find some help here.
My current setup is a STR-DN1080 with external speakers in a 5.1 configuration with input units (Nvidia Shield TV, Sony BluRray player) as well as a LG 4k OLED TV connected through ARC.
For some reason I don't seem to get correct sound levels when I connect a video input through any of HDMI connections in the receiver if the input audio is in a surround format (same result with AC 5.1 as well as various Dolby and DTS codecs tested) where the easiest issue to spot is almost non-existant speech but normal levels on background audio. This is not an issue if I have the input as pure Stereo or if I take in the signal from the ARC on the TV (and use a HDMI input on that unit).
For the AVR setting it doesn't seem to matter what audio format I use (i.e. A.F.D. or 2ch/multi stereo). I've gone through the speaker setup (central speaker was set to +10 dB) and all speakers give a good test tone. Speaker pattern is set to 5.1.
Any idea of how I can start troubleshooting this would be appreciated.
Hi there,
Welcome to the Sony Community.
I'd recommend getting in touch with the support team here who will be best to advise further.
Best wishes,
Sean
