I was given a HCDBX70DBi but there was nothing to connect DAB & AM radio. What do I need to connect them? Thanks Terry
Solved! Go to Solution.
Hello @sestosg20099,
you do not connect the ports together, you connect an antenna to either of these ports (or one if you don't use the other).
See the manual for reference: https://www.sony.com/electronics/support/res/manuals/3293/32936413M.pdf
Thanks nic
