Connect micro CD receiver to TV
SOLVED
sestosg20099
Member
Hi I have been given a Sony CMT-BX70DBi and would like to connect it to my TV to watch YouTube etc. Is this possible and what leads would I need? Thanks Terry
1 ACCEPTED SOLUTION
Accepted Solutions
sestosg20099
Member
Thanks for that Peter l’ll try it
Sent from my iPhone
2 REPLIES 2
Hi Terry,
You can connect your TV to the audio in jack on the front of the CMT using the headphones out of your TV (not really ideal but should work). The cable should be a 3.5mm stereo plug to 3.5mm stereo plug.
Cheers
sestosg20099
Member
Sent from my iPhone
