Hello,
I have an old BDV-IZ100W Home Theater system (Heimkino) and was considering upgrading to the newer but also somewhat aged BDV-N9200W system. How do they compare sound quality-wise? Will I notice a big improvement or not? I could not find any comparison between these two anywhere ...
Any help appreciated.
Thanks in advance,
Best regards,
Giovanni
Hi Giovanni,
well, that's hard to say.
If you compare both systems sound-wise you might not hear a big difference.
But when it comes to versatility the N9200 makes the difference, since it supports Bluetooth, build-in Wi-Fi and also some newer sound formats. Also in terms of picture quality the N9200 will be a step ahead.
Cheers
Hi Peter,
Thank you for your answer. I knew about the versatility but wanted to learn about the sound quality which is the most important to me. By the looks the newer one BDV-N9200W seems to have better speakers but cant tell for sure whether it is a good upgrade sound-wise.
Best regards,
Giovanni
Hi Giovanni,
well, the only way to find this out is to listen to the BDV-N9200W
But unfortunately this is a bit difficult challenge in these weird time.
Cheers
