Hello, New here ...I am based in UK , looking around that the video format is PAL in UK...so should I be setting my M7 to PAL or could I use NTSC for video?
Under NTSC there are more options for video output, which are there under PAL.
Would the NTSC video file play on UK A/V equipment?
Many thanks
ihash.
Hey ihashmat, as you said NTSC isn't supported in the UK, same goes for UK equipment. NTSC format is mainly supported in the USA, Canada, South America & the Caribbean.
