I've just purchased a Sony HD-CX130 and, having tested it in low light, my film has yellow blotches all over it. I took it back to the shop and got a replacement. However, on further testing, the replacement has the same issue. Is this indicative of the quality of this Sony camera or is this a definite problem?
Solved! Go to Solution.
Hi lawgu1, welcome to the Sony Forums
Blotchy, blurred and/or grainy footage (including the sort of problem you linked to on another thread) is pretty much normal for low light perfomance with camcorders at this price point.
Some produce footage that's very grainy, making colours very hard to discern, others reduce the colour intensity almost to monochrome to avoid colour noise and blotching. It depends how the manufacturer prioritises low-light performance: either for image stabilisation, grain, or colour performance, but performance in all three is generally only offered on higher-end cameras.
That said, the Exmor R sensor in the HD-CX130 is generally regarded as a very good low-light performer in grain and colour terms, but the payoff can be some 'aliasing' in the neutral colours, as you've noticed. The CX130 is specifically designed to boost colour performance in low light and this is likely to be a factor in producing this blotching; it'll be great on bright colours (like filming a concert, say) but it will attempt to enrich colour even on neutral areas of the image.
Fortunately there's a setting for it
called 'Low Lux'. It's 'on' by default but you can switch it off – in your Camera/Mic settings under M (Manual) > Low Lux. You might find the image is less 'bright' but the colour aliasing should be less of a problem.
Let me know how it works out
Mick
Mick
