hdr-pj330 LCD Icon removal for web stream?
SOLVED
Sinky22
New
Is it possible to use the hdr-pj330 for a web stream without the LCD icons?
Is it possible to remove the menu, standby/rec and battery icon when the micro hdmi port is used?
I know auto setting takes most icons off after 3 sec but it still leaves the three mentioned above.
If not it would a great software update to provide that solution.
1 ACCEPTED SOLUTION
Accepted Solutions
Sinky22
New
After posting I found this solution that should work for me.
works straight to monitor, just need to test through the Atem mini now.
https://community.sony.co.uk/t5/camcorders/hdr-cx450-is-there-a-way-to-send-clean-hdmi-for-live-stre...
1 REPLY 1
Sinky22
New
