Before and after the calibration of the sensors do not work(dcr-hc22e)?What can i do to sensors start work?
Hello George - Welcome to the Sony Forums
With your camera, it may help if you perform a full system reset to return the model to its factory settings. If you take a look at page 23 of the manual:
http://pdf.crse.com/manuals/2586501131.pdf
You will see that this can be done by finding a small pointed object, such as the end of a paper, and then inserting it into the 'Reset' hole on your camera. This small hole should be located on the same side of the camera as your holding strap.
If this doesn't work, please reply with some more details of the issue that you are having i.e. if there is some kind of error code being displayed.
Thanks,
Simon
Not,its not right answer....nothing changed
Message was edited by: George_Sarsania
Hello again
In your original message, you said that you had calibrated the sensors - what steps did you perform to do this?
Thanks,
Simon
Hello:smileyhappy:
When i include camera on easy handicam i press to "disp batt info" and then press to crosses....
What can i do else?
Thanks, George
Hello again
Does the camera allow to record any video at all now or do you get an error message?
Simon
I can record the video...I can only control remote,but not sensors...
Sorry for my English...
Thanks
