XR-55A84J
NeilHeyes
XR-55A84J
Hi guys,
I had to reset my android TV, I've got a problem now that my TV doesn't show up in the Google tv remote control. I've paired the phone and tv through Bluetooth using pair accessories in the Bluetooth settings, both pair up fine but if I click connect to connect to the phone in Bluetooth settings it doesn't connect. It's been working perfectly but now I'm pulling my hair out with it. The phone I'm using is an oppo find x2 pro running android 13, both are on same WiFi network. In google home settings the TV is there and it shows ambient mode when the screensaver kicks in. Any help would be appreciated.
Many thanks
LightFoot
Spezialist
Hi @NeilHeyes   Did you initialise everything first. Delete the pairing on the phone and rebooting it? Ensuring that it is a fresh install.
NeilHeyes
Thank you for your reply, I factory reset the TV and started fresh, I deleted the Bluetooth connection from my phone and rebooted, the strange thing was it connected to my phone to go through the setup, I will try again tomorrow.
