Using headphones KD-55X8509c and CT780 sound bar
alanxce
I have a KD-55X8509C connected to a CT-780 Sound Bar and latest Sky Q box. My wife is hard of hearing and I am at my wits end trying to find a solution that does not involve sub-titles (most programs from catch up and other sources don't have them) so I think headphones seem like the best possible solution.
Unfortunately all my avenues of investigation so far indicate that any way I connect headphones to the equipment results in the loss of sound for the rest of the room. In these days of advanced technology I can't believe there isn't a good solution here.
I am in dialogue with Sony and have had a somewhat confusing response because I have tried their suggestion and it doesn't seem to work unless I am misunderstanding them.
This is the relevant part of their response
" you may use wired headphones to solve the issue, as you may activate the audio speaker link feature that will allow you to control the volume of the TV and the headphones separately."
So, I turn on tv speakers, that loses the soundbar, plug in headphones and get sound through them and lose tv speaker sound. Not a solution at all.
I have been wondering if there is anything coming out of the tv optical sound output and whether you can plug something into it to Bluetooth the signal to some Bluetooth headphones?
Surely it shouldn't be this difficult?
Thanks in advance for any sound advice,
Alan
27 ANTWORTEN 27
profile.country.IT.title
Marino.Manolo
The TV doesn't has an RCA Out but is possible to use an adaptor SCART > RCA (SCART available is both IN and OUT).
Sorry for misunderstanding (I thought only it works fine or not and not on the TV connections, connections that I know well).
All because of being too focused in responding in English. For me it's still hard.
But the problem of Jack 3.5 mm remains, a problem that is not normally present.
Manolo
alanxce
Thanks for your response Manolo and don't worry your English is great.
I was fortunate to have the a Scart plug/Adaptor to hand which goes into here:
 / AV 1
• Connect with a SCART cable. When you
connect an analogue decoder, the TV
tuner outputs scrambled signals to the
decoder, and the decoder unscrambles
the signals before outputting them.
No signal coming out of it that the wireless transmitter could detect. I was expecting to find the good old fashioned RCA output jacks round the back of the tv somewhere but it seems manufacturers nowadays choose to provide less and less in the pursuit of profit.
What really irrittates me about this problem is the lengths I have to go to as a consumer to prove what Sony tells me is just wrong and ill-informed.
Marino.Manolo
Sorry but, are you sure who the adaptor is SCART IN and RCA OUT? Many of adaptor, like old SCART PlayStation adaptor or old Handycam adaptor, is RCA IN and SCART OUT.
AV1 is SCART IN/OUT, for record from DVB-T to an old VHS for exemple. There should be no imitations.
My apologize for all.
Manolo
alanxce
Hi, I just got a response from Sony ( see below) that I don't understand but have answered with this...
The wireless connection is base station to headphones.
I have tried connecting the base station to both the headphone socket on the side of the TV and in the rear Scart socket with an adapter like this:image.jpeg
I cannot get an audio signal from either configuration.
The headphones are Thomson WHP3311BK-UK Wireless Headphones and being returned over the weekend as clearly not compatible with the Sony, and I doubt any others are compatible either
Any suggestions apart from taking the tv to the dump and buying one from a manufacturer who cares about their customers?
LATEST RESPONSE FROM SONY.....
"Thank you for your recent reply.
In an attempt to solve the issue for you as soon as possible, we recommend you that the link that you sent in the last email shows how to connect a headphone with a base to your TV not a wireless connection.
Please provide us with the serial number allocated on the back of the device for registration purposes."
Marino.Manolo
Have you try both, IN and OUT position? Without an arrow is difficult to choose a right direction.
In Sony maybe don't have understood, they have suggested to plug a cable and not to pair via Wireless?
All of this is very strange (Headphones), I don't have encountered never a case like this (simple maybe) with very late coming solution.
Manolo
alanxce
No, and I may have been misleading with that image as the plug I have is not switchable. I just assumed that if I plugged it in then any output would be available to the transmitter, I guess I would have to buy a switchable adapter to be certain but you can imagine my reluctance to proceed any further with little guarantee of success.
UPDATE In the interests of exhausting all avenues I have ordered a switchable unit to try tomorrow. We'll see 🤔
Marino.Manolo
:pray:
Manolo
alanxce
Well here we are again and I am sorry to say nothing has changed.
Switchable adapter arrived, installed and set to OUT. The wireless base station connected to it gets no signal. In-ear Sennheisers direct to a 3.5mm socket in a cable to the adapter also has no signal.
I can't find anything logical in the tv settings that would indicate I can switch the output to ON.
I think my work here is done, packing up the headphones for return.
I guess it's sub-titles where available or a very loud sound bar for the foreseeable future.
A big big thank you to all those who tried to help.
Marino.Manolo
Last chance, and sorry if you have try (surely), have you set the adapter also to IN?
In this kind of adapter is difficult to have the right direction with IN or OUT.
But all of this is very very strange.
Manolo
alanxce
Yes, I had to really just in case.
I have come to the conclusion (right or wrong) that with sound bar attached all bets are off on what you might expect from the TV.
Oh well, Samsung OLED when the prices rationalise.
