Timers
Malcolm42
Timers
Where do I find timer's in settings on my xr 55 a80j tv
2 AKZEPTIERTE LÖSUNGEN
LightFoot
Spezialist
Hi @Malcolm42
Your TV has a few timers, which one in particular?
You will find the power saving timers in the settings under System -> Power & energy.
If you are looking for the Sleep timer or On timer then press the Quick settings button on the remote (looks like a gear wheel). Move over to the extreme right and select Edit. Once in Quick setting Edit you can tick Sleep timer and/or On timer to show them on the Quick settings menu.
Malcolm42
Thanks I did everything you suggested and it works I can now control the timers.
LightFoot
Spezialist
Hi @Malcolm42
Malcolm42
