Sony KD-55XD9305 - Black screen with vertical lines
StudioTW
Member
Last night while watching TV on my 4 year old Sony KD-55XD9305 a black ‘blob’ appeared in the centre of the screen.
The blob rapidly grew to cover the whole screen & with vertical lines (see images attached) filling the rest of the screen.
Can anyone tell me what this issue might be, whether it can be repaired - or if this is the end of this TV? Ideally I would get this repaired, rather than add to landfill …
Any advice would be welcome,
Thanks.
2 REPLIES 2
daveyh64
Enthusiast
More than likely the panel has failed.
Depending on where you bought the TV it may still be covered under a multi year warranty.
It may be very expensive to repair and does not rule out other components of an older TV failing
in the future.
If buying a new TV some retailers offer a TV recycling scheme.
SkyNet404
Specialist
Hey @StudioTW,
I would suggest doing a forced reset: https://bit.ly/3KmZd77
But if it didn't work, I recommend getting in touch with a Sony engineer: https://bit.ly/3tE97K0.
Hope it help!
