Sky Q and KD-55AF8
SOLVED
mansher123
Explorer
Sky Q and KD-55AF8
Why can't I change the display details when using Sky?.
2 ACCEPTED SOLUTIONS
Accepted Solutions
Almou_10
Specialist
Hi mansher123,
I don't think this is normal, could you try to change the HDMI port, and also try other cables, maybe also soft reset the TV by pressing and holding on the power button on the remote?
Hope this helps,
Aladdin
mansher123
Explorer
Hi Aladdin,
I can't change the HDMI ports, because only ports 2 & 3 support 4K, and the tv is in 2, and my hone cinema is in 3. Both have new hi speed cables. Also by pressing & holding the power button, it just switches the tv off. I guess I'll just have to live with it.
Thanks for trying to help.
Mansher123
5 REPLIES 5
Pascale_F
Moderator
Hi mansher123,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Almou_10
Specialist
Hi mansher123,
I guess you can do that if the remote has an "Action Menu" button, you'll be able to access screen and picture settings while you're on viewing external inputs.
Hope this helps,
Aladdin
mansher123
Explorer
HI Aladdin,
The Action Menu dosn't work with the display settings. By using the home button, I can access the display menu,but on  trying to change  any display, the answer is "not available with this setting (on SkyQ).
Mansher123
Almou_10
Specialist
Hi mansher123,
Hope this helps,
Aladdin
mansher123
Explorer
Hi Aladdin,
Mansher123
