Single Faint vertical line
Bigmatty79
I’ve just noticed a single faint vertical dotted line about 3 inches in on the right of the screen. Any ideas on fixing it? Thanks
4 ANTWORTEN 4
profile.country.IT.title
rooobb
Not so much to try to help you... not a tv model nor a photo... In general terms, panel problems are not addressable without a technicians (and mostly it is too expensive anyway)
Bigmatty79
rooobb
It is surely a component that failed. You should check it out with a Sony support center (it could be the panel or the board managing it)
Bigmatty79
Thanks
Sent from my iPhone
