Gangtrue
Member
Oreo for ATV1 is true
Are you Japanese? I know them as honest and respectable people. Why is this forum, let's talk for ourselves. Please be a little serious and say you will have an update to OREO for ATV1 TVs
55 REPLIES 55
Gangtrue
Member
私は最初のページにいます、そしてあなたの従業員の何人かが私に丁寧に(韓国語で私に手紙を書かずに)答えるのを待っています-ヨーロッパモデルのAndroid第1世代テレビ用のAndroid8または9はありますか?
Translate
I'm on the first page, and I'm waiting for some of your employees to answer me politely (without writing me in Korean)-for European model Android 1st generation TVs Do you have Android 8 or 9?
Gangtrue
Member
As of yesterday there is a Firmware Update to v6.4960 Series XH / 80, 81, 85, 95, A8, XG / 85 Series, 95, AG9, AF9 and Firmware Update to v6.0414
XH90 series. Is it still silent about ATV1?
Gangtrue
Member
Hi!After installing New firm..picture quality  broken...
don't do it yourself.
oreo is a mirage
Piscie
Hi Gangtrue , could you be more specific? What happened to the picture quality? And does it happen with all the sources?
Gangtrue
Member
I use the satellite tuner and the built-in player ... the picture is darker, people's faces are brown or purple. The bright colors are replaced by pastels, like Pana. Moti-onflow is broken, even when you turn it off completely, a slight soapy effect continues.
Joe_Dohn
Specialist
What model TV do you have, and have you tried resetting to factory settings?
Gangtrue
Member
1.KDL-55W805C
2. I have not reset the TV to factory settings yet
Joe_Dohn
Specialist
Try resetting the TV and see if that solves the issue for you.
You can also try removing the satellite cable, tuning without it to reset just the tuner then reconnect and tune normally, if it works, it'll save you the trouble of resetting everything.
Hope this helps!
- JD
Gangtrue
Member
I'm definitely looking for softer colors and a brighter picture. But that's how they decided to buy a new TV from Sonita. But after this mockery I can tell them that I will definitely not buy from their brand. .... Japanese ... sushi. I'm sorry to say that, but to spoil my eyesight for some green money, this is definitely not moral and humane behavior. In order for people to appreciate you, give your best, and success will be with you. Gangtrue
Gangtrue
Member
Is there a way to downgrade the firmware version
