KD-55XH9096 There is a problem, when you change the volume, a banner appears that shows the volume status and a full-length bar appears on this banner. The latest firmware is installed. Question - is it just me or everyone)?
So does mine...
Hi SaenkoVitalik, do you have any external devices connected?
Yes. PS5 connected via HDMI 4. Sound Bar HT G700 via bluetooth ... I disconnected all the cables, even did a factory reset. The result is the same. change the volume gray bar. maybe the firmware is not finished
What's the current version?
All devices have the latest firmware installed
Hey there,
Can you try to switch off the ''info banner'' and check if it'll make it disappear? ''Settings - Watching TV - Info Banner ''.
Hope it helps
