iPlayer and other catch-up apps, wont work
FatBoyOnADiet
Explorer
The iPlayer app, and none of the other catch up apps, wont work on my Sony KD-43XG8196.
I cant see a way to update the app, but I've tried doing the set up on my TV but no joy
When I select an app it just freezes and doesnt load
7 REPLIES 7
It would have been helpful to know the model number of your TV.
Anyway, please check if your TV runs the latest firmware.
Cheers
Tonycv51
Contributor
Have they ever worked? Can only suggest things like :-
- clear data and cache of the apps - edit also try clearing youview cache
- if that doesn't work try re running the initial setup and accept all sony and youview terms and conditions
- last resort factory reset
The other option would be to sideload the Hoshsadiq shortcut versions from github.  You will still have the non working version in Sony Select. The sideloaded ones will be in apps and can be added to favourites. They work on oreo so assume they'll work on an XG
FatBoyOnADiet
Explorer
It's on my post? But its Sony KD-43XG8196.
Checked all the updates, etc
FatBoyOnADiet
Explorer
Cheers, it did work at the start
I've tried initial setup but made no difference
How do I clear the cache? In settings I'm assuming?
Tonycv51
Contributor
Yes in settings. Hopefully obvious which ones but if not some googling might help
Also have you tried a restart in settings or through long press on the remote power button
royabrown2
Hero
@FatBoyOnADiet
Check the clock time on your box, and that the time server it is using is accessible.
This issue has been plaguing Sony TVs lately.
FatBoyOnADiet
Explorer
Clearing the cache seemed to work!
