Increase volume step for arc av receiver
Wardy277
Explorer
I have a 55 xe9005 which is connected to a yamaha rx-v371 av receiver via arc. This all works fine, but the volume up and down is a bit laggy, especially as I generally increase or decrease the volume by 5 steps at a time (from -40dB down to -42.5dB)
Is there a way so that pressing the volume down once, sends the down command several times? I wouldn't might the slight lag if I have to press it less
Tags (3)
4 REPLIES 4
EdwinaU
Moderator
Hi there,
Welcome to the forum.
We'll check this and let you know what information we find. Also, maybe some other members will have some experience with this and can offer some advice.
Best wishes,
Ed
The_Black_Rose
Specialist
Hi Wardy277,
Do you control the volume using the TV's remote control or the receiver's remote control?
Cheers,
The_Black_Rose
Wardy277
Explorer
Thanks for the reply. I use the TV remote to control the reviewers volume.
The_Black_Rose
Specialist
Hi Wardy277,
I'm no so sure that this function will even be supported to be honest.
Cheers,
The_Black_Rose
