How to remove info banner on top of screen
Sat.sb
New
How do I remove the banner at top?How do I remove the banner at top?
 I would appreciate your help.
3 REPLIES 3
LightFoot
Specialist
Hi @Sat.sb  Home -> Settings -> Channel setup -> Info banner -> Off.
RJA1963
Explorer
There is no Info Banner option that I can find on my KDL43WF663 Bravia tv.  Any other ideas?
LightFoot
Specialist
Hi @RJA1963   You should note that you have a Linux TV (not Android). As far as I know, there is no settings to turn off the info banner on a Linux TV. It appears when the audio format changes, so one work-a-round is to set your PS4 to PCM or Normal so the audio format is fixed.
