Connected devices.
muvoda
Connected devices.
Hi all, I have a 55XH9505 tv, and I have removed two items that were connected to the tv, ie, Humax BT box and a sound bar ( upgraded so I don't need them) my problem is.... Can I delete these obsolete items off the page where the connected devices are listed?? Because I have too many devices listed now, and half of them are still showing that I don't use, would a 'soft' reset do the trick? If not, could one of you guys give me some advice. Kind regards muvoda.
20 ANTWORTEN 20
Anonymous
Nicht anwendbar
Check if you can edit them here: Press the HOME button, then select [Settings] — [Watching TV] — External inputs
muvoda
Hi @Anonymous Thank you for your response to my query, I have tried that thanks and it does not delete the items that I once used, they are still showing, I am at my wit's end with it, so apart from doing a full factory reset ( which I would rather not do) I think I will just have to suck it up!! I did try a 'soft reset' but it didn't make any difference. Thank you again for your input. Regards muvoda.
Anonymous
Nicht anwendbar
Hey @muvoda,
In the external inputs menu, there's an option called ''Manage Inputs'', you can edit the inputs, change the naming and I think remove them as well.
Hope it helps.
muvoda
Hi @Anonymous, thanks for taking the time to respond, I have had a look at that, but all you can do is 'Hide' or 'show' you cannot delete, and ironically, the unused devices that I have got rid of are showing (STILL) in the sync device's menu, weird, I really don't think there is anything else that I can think of, apart from a factory reset and you know what I feel about that, so I am just going to leave be. So thanks again. Regards muvoda.
Anonymous
Nicht anwendbar
This may be a far fetched idea, but can you disable Bravia Sync, do a soft reset, and see if they're still there or not before enabliling it once more?
muvoda
Hi, that is an excellent idea, I don't know why I never thought of it, I will definitely have a go at it and post my results, thank you so much @Anonymous.
Anonymous
Nicht anwendbar
Hopefully it's not just an idea, and it can actually work! Waiting to hear the good news from you, fingers crossed.
muvoda
Hi, I will post at the weekend because of work issues. Cheers muvoda.
Anonymous
Nicht anwendbar
Sure, take your time and hope next time you have good news for us!
