Can I use a Firestick with my Sony LCD W4000?
Pendragon2
New
Advice please! I have a SONY 32” LCD W4000, and it is brilliant! I am shocked to see that it is nearly 12 years old.
I wonder whether a firestick will work with this model, or whether I should simply replace the TV with a Smart TV.
7 REPLIES 7
spannerzone
Member
Yes it should fine, I use a Firestick with my 32W4000 and have no issues.
Mine is still giving excellent results, it did cost £900 in 2008 but an excellent TV
Pendragon2
New
Brilliant! Thank You
Anne
Pendragon2
New
I’m back for more help. I have the firestick for my LCD W4000, and am ready to go. It won’t connect, and I’m guessing it’s to do with the Wi-fi. There appears to be no ‘network feature’ in settings to enable me to connect. Any thing I should be doing differently?
spannerzone
Member
It should be pretty straightforward, following this guide
https://www.wikihow.com/Connect-Amazon-Fire-Stick-to-WiFi
Apparently if your wifi network is a hidden SSID then it's not possible
profile.country.IT.title
rooobb
It should work, but having my self the same tv and an OLED A1 ... it is not that brilliant I can assure you. And 32" is really small nowadays. Obviously if you have wish and money to buy a proper new tv :wink:
Pendragon2
New
Thank You. I’ve just managed it! I’ll see how it goes!
Anne
Pendragon2
New
Thank You. Some key instructions were missing, which would have been obvious to a technically literate individual! However, I persevered and it’s working. Thanks for your help. Appreciate it!
Anne
