Hi All,
I have a Bravia 4K 55XG8796 with Bose Solo 150 attached on optical cable, but I can't synchronize the bose remote control to work wit TV. Any idea? just tried with the code 2679 (as it worked with VirginMedia Horizon Box remote control).
Hi nicuflociuc,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi nicuflociuc
It doesn't seem that your TV supports controlling devices connected via Digital Optical. The option to use Control for HDMI is always there though.
Win_88
You should check your Bose Solo manual, for sure the code cannot be the same as the virgin media box! If I had a look at the right manual it should be 00000
