Aj80 55 - sound not in sync with picture
SOLVED
Reidster78
New
Recently bought a 55" aj80 oled TV. I have virgin TV, so have connected to my tivo box using hdmi 2. Watching the football on BT sport ultimate, I can hear sounds before it happens.
Watching on Sport sound mode, imax picture.
Tried various settings but finding it hard to fix! Any ideas, settings changes appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
Eskimosony
Member
I'm going to tell you something mad....change your HDMI cables, you want Brand New FAST HDMI 2.1...the ones used for 4K/8K and XBox and PS5. The best ones they make..👍
JuicEBitz® 8K HDMI 2.1 Cable [1M Cord] Ultra High-Speed 48Gbps Lead | Supports 8K@60HZ 4K@120HZ 4320p QLED TV, 3D, Ethernet Function, eARC, UHD Gaming PC, Xbox One X/S, Home Theater, PS5/PS4, Sky Box https://www.amazon.co.uk/dp/B093HKF55T/ref=cm_sw_r_apan_glt_i_3YYBSR5AMS0Q63ZP0A63
2 REPLIES 2
Eskimosony
Member
Reidster78
New
Cheers, I've had the lead I used kicking around for a while, so that may do the trick. Thanks!
