Ability to switch to TV viewing mode from Home menu with PROG +/- or number buttons
winzy54
New
Hello.
After 7.0 update, When i click on "PROG +/-" Buttons, or on some 1-9 buttons (on some app that use this buttons) im getting the Analog TV screen.
this is a new feature is called "Ability to switch to TV viewing mode from Home menu with PROG +/- or number buttons"
There is an option to disable it?
4 REPLIES 4
Mick_D
Moderator
Hi @winzy54, welcome to the Community.
Can you let us have the model number of the TV?
Thanks
Mick
winzy54
New
My tv model is: KD-65XF9095.
Software version is: PKG6.5629.0177EUA
I have this problem when I watch live TV using an app. And I can’t use the numbers as it changes to analog tv when I press a number.
Tenneen9000
Member
Hi Winzy54,
Well, I don't think this is a feature that you can enable/disable as a user. Your best bet is to contact the app developer as they'll need to have a workaround for this feature.
All the best,
Tenneen9000
winzy54
New
Hi.
The programmer already tried to workaround it. But with no luck.
Can anyone share a possible workaround that i could share with the developer.
Thanks for the help
