My new Sony is supposed to be 100-400 hertz but where the plug socket goes into the tele it says 50Hertz and the picture is good but nothing like it was in store. Have I received a different tv
Solved! Go to Solution.
MY SAT DISH IS A SKY DISH SO HAS 2 CONNECTORS TO PLUG INTO A SKY BOX. MY TV ONLY HAS 1 CONNECTOR SO DO I JUST CONNECT 1 CABLE FROM THE DISH?
SO AS THE REP SAID THE TV IS SUPPOSED TO BE 400HERTZ SO HES BEING TRUTHFUL ?
@pecartl30 wrote:MY SAT DISH IS A SKY DISH SO HAS 2 CONNECTORS TO PLUG INTO A SKY BOX. MY TV ONLY HAS 1 CONNECTOR SO DO I JUST CONNECT 1 CABLE FROM THE DISH?
Yes. And if you can’t get any channels on it, try the other one.
NB: By convention, using all caps is SHOUTING, and best avoided, unless you really are shouting.
As has been said above, the TV takes in mains at 50Hz, runs its panel at 100Hz (correction: 50Hz), and offers MotionFlow interpolation at 400Hz.
So unless he claimed that the panel runs at 400Hz, yes, he was being truthful.
@pecartl30 wrote:I WAS TOLD THAT I HAD PURCHASED A 400 HERTZ TV.SONY BRAVIA KD-55XF759 6 HOWEVER THE DOCUMENTS TELL ME AT FULL RESOLUTION 4096 X 2160P ITS ONLY 50-60HERTZ . IT DOES HAVE SONY MOTIONFLOW. HAVE I BEEN DUPED OR IS THIS TV INDEED 400 HERTZ. THERE IS NOTHING EITHER IN DOCUMENTATION OR PACKAGING TO CONFIRM BUT THE ONLY REFERENCE IS TO THE POWER PLUG AT 50-60 HRTZ AND THEN WHAT I HAVE SHOWN ABOVE. CAN ANYONE HELP? THANKS
400Hz mains is sadly unavailable in the UK, or even in the US, so Sony are unavoidably restricted to the 50Hz AC coming out of the mains in the UK, and 60Hz elsewhere. But worse, the power comes out of the brick at 0Hz (DC).
However, here is the spec for this TV, which quotes:-
MOTION ENHANCER Motionflow™ XR
(NATIVE HZ) 400Hz (Native 50Hz)
So there’s your 400Hz, right there, and the native 50Hz it looks like the panel actually runs at.
i.e. It looks like he gave you both numbers, correctly.
But I don’t know where you got that 100Hz for the panel from......
Sorry no intention of shouting. I just had the caps locked on on my laptop.
Thank you you for your help.
