NEX-3 battery runs down when camera off
SOLVED
profile.country.ru_KZ.title
jj_gilham
Visitor
My Nex-3 has recently started completely depleting the battery when turned off.  It will go from 100% to 0% in about 48 hours with the camera off.
I had version 1 of the firmware and this morning I  installed version 3 of the firmware to see if this fixes the problem.  Does anyone have any information on this?
1 ACCEPTED SOLUTION
Accepted Solutions
Blencogo
The battery drain problem was fixed in Version 2.0 firmware upgrade.  This is incorporated in Version 3.0
I found this fixes the problem completely.
:wink:
3 REPLIES 3
Blencogo
:wink:
jj_gilham
Visitor
The firware I loaded last night was referred to as 1.3 - is this the same as the Version 3.0 upgrade?
I'll report tomorrow on if the firmware fixed my issue.
thanks,
jeff
jj_gilham
Visitor
It appears the upgrade to 1.3 solved the problem.  I checked this morning and the battery was still at 100% so problem solved!
Thanks for the information
Message was edited by: jj_gilham
