Xperia 5 IV Always on Display (Ambient Display) PROBLEM!
Zlays84
As of this morning I have strange problem with my Always on Display... It lights up with maximum brightness and with green tint filled...
I tried rebooting the phone but no luck...
Also I have this "ghost" app problem since last update...
But now this...
Btw Display is working properly...
Anonymous
Nicht anwendbar
Hey @zlays84
For the ghost app issue, try the below steps:
Settings-apps- see all apps- Google Play store- storage- clear cache- clear storage.
Then go one step back and press on disable
Restart the phone
And then follow the same steps to enable Google Play Store
And test after that to check if the same battery issue will be there or not
For the always on issue, try to force restart he device and then disable the always on option and then enable again and check
You can also try in safe mode and check if the same thing will happen again or not.
