Xperia 10 Plus Unsupported SD card
profile.country.PL.title
MickeyPlus
Member
Xperia 10 Plus Unsupported SD car After updating to android 10, the phone stopped seeing cards above 8gb. After inserting a 32 / 64gb card, it displays the notification Media SD card not supported. After entering the settings, the formatting is 20%, shortly after starting it displays a message about the formatting completed, but the notification still occurs and the cards do not work. Any ideas?
34 REPLIES 34
MickeyPlus
Member
Hi guys! I reflash the phone with other fw region but sd still doesnt work. Well only update can fix this
Johnwbt1
Explorer
Did a factory reset on my phone over the weekend..
Phone running smoother now, bit still no access to SD card, as before
Not now seeing the maintenance symbol on start up..
So think need an update from don't to fix
I'll try calling them tomorrow
Ps.. don't know if doing a software repair via a pc would improve the situation
profile.country.NL.title
Strampke
Go for a Xperia Companion software repair.
Charge battery at > 80%, no SD card inserted, maybe leave SIM out as well.
Plus: don't restore the full backup. Just install the most needed and middle-of-the-road apps.
Make every influencable circumstance as favourable as possible.
You did test a SD card from a friend already?
Johnwbt1
Explorer
Thanks Strampke
This SD card works fine in my pc.
Also have a different SD card, tried that and got the same response...
Someone said only sees SD card max 8gb Inp now after Android10 update
I'll think about doing the recovery option.
Just so time consuming seeing up the apps again with all login details..
On the plus side, now only using 40 percent storage in 64gb phone
As all photo now released to cloud.
So can live without SD card if necessary
profile.country.FR.title
JM--RG
Explorer
Bonjour,
J'ai le même problème que vous après la mise à jour A10,
Avez vous trouvez une solution ? Ou une réponse de Sony ?
J'ai contacté Sony et attend leur réponse.
merci.
MickeyPlus
Member
Non, les cartes ne comprennent toujours pas
shooorick
New
После обновления ПО на данной модели, устройство перестало видеть SD карту. Появилось вверху слева экрана системное уведомление "Проблема с накопителем (SD-карта). Нажмите здесь,чтобы исправить". Нажимая на данную ошибку, телефон переходит в меню: "Отформатировать устройство "SD- карта" варианты : отформатировать или отмена. При нажатии "форматировать" появляется: "SD-карта форматируется", доходит до 20%, далее появляется надпись : "Устройство "SD- карта" готово к работе " по нажатии "готово". Ничего не изменяется, остается та же ошибка и устройство карту не видит и не может использовать. До обновления данная карта использовалась в этом же телефоне, в результате этой ошибки были утеряны все фото и видео за год пользования смартфоном. ВСЁ РАБОТАЛО!!! НЕТ НИКАКИХ ПРОБЛЕМ С КАРТОЙ!!! Карта работает в любых остальных устройствах, видится компьютером, записывается/форматируется и т.п. РАБОТАЛА ДО ОБНОВЛЕНИЯ В ЭТОМ ЖЕ УСТРОЙСТВЕ!!! Не пишите пожалуйста в ответах: проверьте карту,а какой производитель карты, а может это плохая карта. С КАРТОЙ ВСЕ ОТЛИЧНО! ПРОБЛЕМА ПОСЛЕ ОБНОВЛЕНИЯ!
Johnwbt1
Explorer
I did a system reset and also software repair.
Neither option has the fixed the problem.
Still remains
Come on Sony....!
Lord_viridis
On the Samsung card, what colour is the side.
Did you check in H2test-w?
Johnwbt1
Explorer
It's not important about the sd card.
I also have the same problem with this phone which is still under warranty...
Everything worked fine before the upgrade
And after nothing...
The sd works fine on the computer ana shows all the data correctly
I did a phone reset and also software repair
But neither have cured the problem
