I snapped the pin from the charger port and its stuck in the charger.
profile.country.en_GB.title
matnolan3
Visitor
I snapped the pin and super glued it into the right place in, and it seemed fine.
But I stupidly put the charger into the port while the super glue was obviously slightly wet.
And now the pin is super glued in the charger and I can't get it out.
Can I buy a replacement charger port for my VAIO Laptop?
Model: PCG-7134M
Pics:
http://i552.photobucket.com/albums/jj346/matty-nolan/b9825a3a.jpg
http://i552.photobucket.com/albums/jj346/matty-nolan/4a9f212b.jpg
Message was edited by: matnolan3
1 REPLY 1
rich912
Contributor
You are quoting the chassis number but I think you will find that you model is VGN-NR32(x/x).
If this is the case the power connector is on the rear of the machine and is soldered to the motherboard.
I suggest that you contact one of the Sony service partners: (http://support.vaio.sony.eu/computing/vaio/contacts/asc.aspx?l=en_GB&m=VGN-C2S_P )
...or Laptop Repair Specialist (http://www.laptoprepairspecialist.co.uk/index.html ) who sorted out a similar problem for me at a total cost, including VAT and delivery, of approx. £120.00.
Go n-éirí an bóthar leat
